18-5 Step 5: Attached the VA-146 Bearing to the Tank Attach Brackets.
18-7 Step 1. Bent fuel sender float wires as per instructions shown in Figure 1 and also collaborated eith instructions provided with senders.
18-7 Step 2. Temporarily installed senders , then adjusted float wires to get full travel of float arm. Checked for travel with Ohm meter, Readings as follows:
Right Sender: 31 Ohms Full Tank, 238 Ohms Empty Tank.
Left Sender: 26 Ohms Full Tank, 236 Ohms Empty Tank.
These reading correspond to readings of senders prior to installation.
18-7 Step 3. Used tank Sealant to final install Fuel Senders.
