Ivans RV 10
RV10
Bottom Rudder Epoxy for Brass Inserts
Decided to make screw attachments stronger than what is suggested.
Drilled pilot holes for 4-40 screws to fit 4-40 Brass inserts into aft Bottom Rudder Fairing for tail light assembly.
Epoxy and Flox from West's was used to secure Inserts into Fairing.
Let cure for a couple days then sanded for a nice fit.
Brass Inserts work really well as the have opposing directional serrations that make it nearly impossible to strip out and turn once epoxy cures.
Bottom Rudder Fairing to be riveted in place later during wiring.
RV10 Home
519
Aileron Actuation
Ailerons
Auto Pilot
Baggage Area
Baggage Door
Elevator
Empennage Attach
Fairings
Flaps
Horizontal Stabilize
Inventory
Rudder and Brake Ped
Tailcone
Tailcone Attach
Vertical Stabilizer
Wing Tips
Wiring
