Trimmed aft edges of Rudder Tip Fairing to get good fit between flange and rudder trailing edge and for tip faring to fit nicely into rudder. Had to trimm flange for correct fit.
Then drilled #40 and clecoed into place.
Then final drilled #30 and clecoed.
Removed fairing and deburred and dimpled rudder skins.
Countersunk holes with duburring to as before.
Riveted the Rudder Tip Fairing using CS4-4 Blind Rivets.
