Took awhile but finally assembled Elevator trim cables as per instructions in Figure 5. Finger tightened jam nuts.
Using battery charger I ran Trim Servo to full retracted position. Then adjusted the engagement of rod end bearings and elevator trim cable positions to achieve full extension of cables. Tightened Jam nuts.
Ran servo back and forth and noted no binding or interference of parts.
