Ivans RV 10
RV10
Trim Servo Installation
Installed the Trim Servo to the Trim Mount Bracket and Trim Servo Spacer as in Figure 4.
Attached the Trim Servo Sub Assembly to the Trim Bellcrank as in Figure 4 Also.
Installed the two CT Q-43 Elevator trim cables to the Trim Cable Anchor Brackets as per Figure 5.
Adjusted cables for center of anchor brackets and tightened jam nuts.
RV10 Home
519
Aileron Actuation
Ailerons
Auto Pilot
Baggage Area
Baggage Door
Elevator
Empennage Attach
Fairings
Flaps
Horizontal Stabilize
Inventory
Rudder and Brake Ped
Tailcone
Tailcone Attach
Vertical Stabilizer
Wing Tips
Wiring
