Ivans RV 10
RV10
Rudder attach and Travel
Bolted the Rudder to the VS on the Top and Bottom attach points only.
Adjusted rod ends as necessary to achieve proper travel and clearance.
Then adjusted middle rod end for proper alignment.
Rudder swung freely.
Adjusted for proper travel of 35 degrees and then tightened jam nuts on Rod End Bearings.
Removed Rudder and VS
RV10 Home
519
Aileron Actuation
Ailerons
Auto Pilot
Baggage Area
Baggage Door
Elevator
Empennage Attach
Fairings
Flaps
Horizontal Stabilize
Inventory
Rudder and Brake Ped
Tailcone
Tailcone Attach
Vertical Stabilizer
Wing Tips
Wiring
