Ivans RV 10
Date:  10-30-2007
Number of Hours:  0.70
Manual Reference:  11-6
Brief Description:  Push Rod Assembly and Installation
Re installed the Inserts and Riveted them on with MSP-42 Rivets.
Installed jam nuts on rod end bearings and threaded onto inserts.
Installed the Elevator Pushrod to the WD-605-L-1 and WD-605-R-1 Elevator Horns and to the F-635 Bellcrank AssemblyUsing hardware depicted in Figure 3, Detail A & B.
Once assembled I checked for proper degrees of travel and had to file the F-1011B Stop/ Doubler to get necessary travel.
