Ivans RV 10
RV10
Elevator Pushrod Assembly
Bolted the elevators back on to HS.
Cut the Push Rod to length of 73" and deburred edges.
Installed the VA 101 Threaded Inserts into Rod to just past the beveled edge of Insert.
Used a Solid Hexagon shaft tapped to 3/8-24 for a template for drilling rivet holes to #30.
Removed parts and deburred holes.
Sprayed primer heavily on inside of Push rod and rotated until surface was completely covered.
and let it dry for a day.
RV10 Home
519
Aileron Actuation
Ailerons
Auto Pilot
Baggage Area
Baggage Door
Elevator
Empennage Attach
Fairings
Flaps
Horizontal Stabilize
Inventory
Rudder and Brake Ped
Tailcone
Tailcone Attach
Vertical Stabilizer
Wing Tips
Wiring
