Ivans RV 10
RV10
Vertical Stabilizer Attach
Final Drilled the top two 3/16 holes in the rear spar doubler to #12.
Bolted the Vertical Stabilizer to the F 1012 Aft Fuselage Bulkhead Assembly. w/ AN3 bolts called for in Figure 6.
Final drilled the four remaining 3/16 holes #12, then machine countersunk the bottom two.
Istalled hardware called for in Figure 6.
Match drilled #30 then final drilled #12 as called for in Figure 5.
Removed and deburred all holes then assembled VS with hardware mentioned above.
All bolts torqued to 30 in/lbs.
RV10 Home
519
Aileron Actuation
Ailerons
Auto Pilot
Baggage Area
Baggage Door
Elevator
Empennage Attach
Fairings
Flaps
Horizontal Stabilize
Inventory
Rudder and Brake Ped
Tailcone
Tailcone Attach
Vertical Stabilizer
Wing Tips
Wiring
