Riveted together the 1011 Bulkhead, Bulkhead Stiffener, Hor. Stab. Att. Bars and the Rudder Cable Angle Riveted nut plates to Rudder Cable Angle Riveted the Nut Plates for 824B Cover Plates to 1073 Skins Riveted the Hor. Stab. Att. Angle to 1010 Bulkhead Riveted together 1008 L&R Frames and the Rudder Cable Bracket Installed Snap Bushings in Rudder Cable Bracket Riveted the 1007 L&R Frames together Installed Snap Bushings into 5/8 holes Riveted the 1006 DBulkhead to the 1006A&C Bulkheads 1006B is riveted when Fuselage ia attached
