Brief Description: Battery Channel and Bell Crank Assemblies
Separated Battery Channel parts and deburred , final drilled and finished edges Final drilled the 3/32, 1/8, and 3/16 holes of Battery/ Bellcrank Mount Then CS the appropriate holes Deburred and finished edges Made 635B Spacer from supplied material and marked as in drawings and drilled hole Clecoed the 635 Elevator Bellcrank Assembly and match drilled the second hole of spacer Final drilled the rest of the holes Disassembled and Deburred and finished edges
Riveted the 635 Elevator Bellcrank Assembly together. Riveted nut plates into place with flush rivets Snapped the Tabs of the Battery Channels into notches of Battery/ Bellcrank Mount then riveted channels into position Riveted the 1012A &B Bulkheads, 1056 Rudder Stop and 1012E Tie Down Together Made mistake on Rudder Stop Riveting and replaced rivet w/ OOPS Rivet
