Brief Description: Clecoing Frames, Bulkheads, Ribs and Skins
Placed forward Bottom Skin upside down on horses and clecoed the 1007,1008,and the 1010 Bulkhead to the Bottom Skin Put the 1047F Stiffeners in notches in frames 1008 and 1007 and Bottom Skin Centered marks on Stiffeners and started match drilling holesin Stiffeners and Bottom Skin 1047F are now L & R Dedicated Repeated above Steps for 1047G Stiffeners !047G now L & R Dedicated Clecoed L & R Bell Crank Ribs to Bottom Skin and the 1007 Frame Final drilled common holes of Bellcrank Ribs and Frame Put 1047C,D, and E Stiffeners in Right side of frame Clecoed 1073R Skin to Frames and Bottom Skin Repeat same steps as previously done for other Stiffeners Made replacement 1047 Stiffeners Thanks Vans!
