Ivans RV 10
Date:  7-28-2007
Manual Reference:  9-17, 9-18
Brief Description:  Finish Elevator
Riveted Hige Halves to Elevator and Trim Tabs
Attached Trim Tabs to Elevator with Hinge Pins
Drilled hole in Rear Spar and Aft end of Root Rib Flangefor Safety Wire Istallation
Bent hinges according to plans
Screwed up one hinge and had to order another
Will replace hinge pin later when Assembling control surfaces to Emp.
Safety wired the one Hinge Pin done correctly
Notes on Trim Tab to replace hinge
