Brief Description: Riveting/ Back Rivet Trailing Edge
Riveted Top Ribs together and to Spar
Riveted Skins to spar Flanges
Riveted the Counter balance Rib to Spar.
Back Riveted Trailing Edge. I used an 8ft Steel Table as a platform and weighted down the Rudder with two 25# bags of dog food. This held rudder precisely and ended up with a perfectly straight trailing edge. As I was riveting I alternated top to bottom, left to right until all rivets were mostly set. Then went back and final mushroomed them all from the center out, alternating left to right.
