Finished Prep on Shear Clips and Stiffeners. Began prep on Rudder Horn and Striker Plates. Counter sunk and final drilled holes as per Figure 2 page 7.4
Clecoed Bottom Rib Assembly as per Figure 1 page 7.4.
Attached Rudder Horn to Bottom Rib and match-drilled holes as per Figure 3 page 7.4.
Prepped the R1002 Spar and attached Bottom Rib assembly to Spar. Final drilled and Counter sunk all holes as per Figure 4 page 7.4.
Clecoed R1015 Stiffeners to Shear Clips and final drlled holes as needed.
Clecoed Reinforcement Plates to to Spar and final drilled holes common to Shear Clips Reinforcement Plates and Spar Web.
