Ricks Web Site
Date:  10-8-2005
Number of Hours:  5.00
Manual Reference:  6-1
Brief Description:  Assembled horizontal stabilizer skeleton
Clecoed the two HS 902 front spars and the HS 907 double plate together, match drilled to # 30. Fabricated the HS 908L and 908R attached angles and fit them to the from spar. Drilled alignment holes. Clecoed the HS 908L/R angles to the front spar and matched drilled them to the spar. Clecoed the two HS 903 Rear spars together wit the HS 906 rear spar doubler plate, match drilled to #30 holes. Clecoed the eight SH912 outboard hinge brackets to the rear spar and matched drilled to #30. Marked all parts as right/left for reassembly.
Clecoeing the front spar
Prep work
Prep work
Deb clecoeing
Deb clecoeing
