Brief Description: Match drilled and dimpled skeleton and skin
Back riveted plate nuts to E615pp trim access reinforcement plate. Sprayed with primer. Match drilled left elevator skeleton and skin. Dimpled ribs and stiffiners, and deburred with scotch brite pad. Opened #30 holes to #40 on bottom of skin and spar for pop rivets. Dimpled E 902 spar.
