Greg's Model 12 Build
Date:  6-22-2025
Number of Hours:  2.50
Brief Description:  Wingtip and aileron
Finished fitting the wingtip to my satisfaction. Accidentally dropped the magnetometer from the height of the leading edge onto the concrete floor. Something rattled inside of it so I took the lid off. Found a solder connection broken loose, it would appear. I'll call GRT and see what they recommend to do with it. Began sanding the aileron tip and glued it to the aileron. Put painter's tape on the drag/anti-drag wires near the parts that will receive clear coat in the near future.
The solder is what made the rattle sound in the Magnetometer
