Trimmed washers on the rear spar aft brackets to provide clearance for the wing walk skins to lay on the rails flush. Used a standard cut-off wheel on the dremel. Applied the 1st coat of Clear Coat to the bays on both wings. It took more CC than I expected. Approximately 30cc per wing. The 2nd coat will probaby require about half that much based on previous experience.
