Brief Description: Top walkway rails aft of rear spar
Finished making the 4 short walkway support rails that go behind the rear spars extending to the trailing edge on the top side. Used a cardboard template traced from the rib to shape the rails. Used the first rail to mark out the remaining three. Scuff sanded the ribs for better glue adhesion then glued and clamped all four in place. I used two 5/8" staples per rail to help hold them in place since the T-88 glue is very slippery and the pieces want to slide all over the place when clamp pressure is applied. I previously used the same method with the longer rails yesterday with success.
