Brief Description: Walk way supports, wing tip support rails
Glued and stapled the inboard support rails to the top side of both wings. Glued and stapled the top side wing tip support rails to the tip rib. Began shaping and fitting the -47 support rails that get installed behind the rear spar. Tedious work using 1/2x5/8 material.
