Removed all the sheet metal and put it in the attic. Put all loose items and tail feathers in the trailer . Bobby wiped most of the grime off the fuse structure with rags and water. While doing so we could see where the primer is beginning to crack and lift from some of the forward crossmembers. It's approximately 15 years old. Yet another reason to strip it and get it powder coated.
