Finished making the right wing wiring loom, heatshrunk cable markings on both ends of cable, fitted the 4 way plugs, joined and attached the wingtip. Mated the right wing onto the fuselage, attached the flap rod and had to enlarge the hole slightly as it was rubbing on the flap rod. All works a treat. Left wing fitted with wingtip and position and lights working.
