Using the original lighting setup of 2 x 75 watt lights in each wingtip, made a total load of 300 watts, divide this by 12 VDC (300 divide x 12 = 25 amps) Quite a high current draw on the system, so I changed these globes over to LED (7 watts each x 4 = 28 watts). Not only are the lights brighter but only draw approx 2.5 amps total. So removed the lights, fitted the new LED globes onto the original connections and fitted, they are fantastic.
