Mounted the bracket I had made a while ago for the pitch servo motor for my Trio Pro Pilot, rivet the top and pop riveted the sides, drilled and mounted, cut/measured the trio push rod, shortened the cable. Soldered the very small attachments for the plug and all wiring neatly attached as per photo.
