Mounted the OAT probe just under the right horizontal stabilizer and ran wires. Very difficult as I had to get right down into the back of the fuselage to drill holes and cable tie. I ran the two thin wires in some electrical sleeving to protect it, came through small holes I drilled into the interior frame, these had rubber grommets, shortened the cable and spliced/soldered together with heat shrink over the top. Vacuumed a heap of swarf and drillings from the back as I don't think I will be down there again. Drilled the platenuts for the Dynan 10" skyview so it can be mounted, mounted the battery backup and engine module just behind the screen as there s plenty of room.
