Back on the fibreglass, rubbed back the wheel pant and gave it a coat of the white epoxy filler, started the long process of sanding, sanding and sanding, this flocoat stuff is great as it fills all the pin holes, just have to sand it off as I brush it on. Sanded down the flo coat (took quite a bit of sanding) primed these parts. Cut in half and made my metal attach strips and glued, then fibreglass over the top. These strips help hold the two halves together.
