Drilled and riveted the platenuts on the T-708 plate so I can mount the fuel float sender unit, made a vent line clip and mounted the fuel cap. This job was very messy as it was time to use the bucking bar and rivet gun with sealnt thrown in for good measure. I had to do a couple of rivets again as I wasn't happy with the result. Steep learning curve this job.
