Finally got around to sealing the baffle onto the tank, ye ha, finally done, no more tank work. Having the pnematic squeezer helped in finishing off the tank as squeezing the baffle worked a treat. All done and now I will wait to pressure test, I added a bit extra sealant up on the corners of the last ribs as this is where I had a slight leak from the first tank.
