Started to remove the plastic from bottom wing skins using a soldering iron to peel away strips along where the holes are. This way at least the skins are partially protected from any scratches they may get, and also started the tedious process of deburring the newly drilled holes. Deburring the holes on the wing ribs as well and dimple as I go
