Clecoed the ribs into the leading edge skin, quite tight so took a bit of grunting to line all the holes up. The cradle definately helps in this procedure. I then placed it onto the main spar and once again everything tight, but superb result. The matching of the main top skin and the leading edge is perfect, a very fine even line can be seen all the way along, very impressed.
