Finishing off the platenut attach points for the bottom cover of the fuel pump assembly and the forward bottom cover. I had to screw them both in place to get the right fit and drill the extra 4 holes up near where they join each other. Drill and fit platenuts into the covers. I decided to fit the fuel pump and filter in for good this time, as I can feed any wires underneath this part if need be. I'm definately glad I used flexible braided fuel line for the wing lines and main fuel line to the firewall, makes it a lot easier. Drilled a hole in the firewall for the fuel line to the engine, made a doubler plate and riveted this on. I used high temp silicon in between the plate and washer to the firewall forward bulkhead nipple, attached the fuel line, yippee this parts done. Drilled the hole for the heat box. Mounted the heater box with high temp silicon and the bolts.
