Peters RV7A
Date:  4-25-2009
Number of Hours:  4.00
Brief Description:  Fuel Tank
I decided to take off the left tank from the wing as well and prime the tank the same as the right one. So remove, scotchbrite inside and edges, give it a coat of grey primer.
I then scotchbrited the exterior of the tank and also gave it a coat of 2 pak primer/filler.
Placed back on the wing, torqued and marked all the bolts, scresw fitted, wing done.
