Now for another steep learning curve. I tackled the vent line first and after a couple of aborted attempts using scrap tubing I got the desired bend I needed, using tube benders and fingers, to go over the angle and underneath the rudder cable. This was a tricky part of the vent lines I felt. I hand bent the rest until I got to the fittings near the front and then I used the tube bender to get a nice 90 degree bend to attach to the fitting. Using my drill press I smoothed off the thread and polished it with scotchbrite pad and then cut the 45 degree angle needed on the fitting. Screwed everything in place, another hurdle done.
