A laundry list of things to do now, I riveted on the 8 x K1100-06 platenuts onto the rear of the fuslage where the F-824 cover plates go, vacuumed out as much of small aluminium filings as I could see. Deburred and dimpled the 2 x side seat rib, drill matching holes with the forward seat floor, got eady to corrosion proof. Having a good look at the plans and working out where some platenuts go in relation to the tunnel attach on the centre seat ribs, drilling where required. Just doing lots of getting all the parts finished, dimpled, etc etc before final assembly. Corrosion proofed side seat ribs, primed and also primed a lot of angle.
