I cut the wing walk doubler plate to size, drilled this using the skin as a template, deburred the holes and dimpled. Once again using the soldering iron I cut strips off the skins along the rivet lines, clecoed the skin to the skeleton ready for match drilling. After corrosion proofing the wing walk doubler and priming I match drilled the skin, deburred and dimpled.
