Getting down to the last part of the tank, I fitted and seal the vent line and fuel line making sure I had enough sealant on the inside and around the attachments.Then screwed tight the plate and fuel sender unit, also checking the resistance of the sender in full and empty mode, checks perfect. Next week I will finally seal the baffle on and pressure test soon after.
