After mounting the tank and cleco it into position the fit is perfect, no gap and fits nicely between leading edge. I drilled out the holes in the end rib for the baffle and Z bracket mount, removed the leading edge and drilled out those holes in the Z bracket, remove the tank minus the two end ribs and drill out the rest. A lot of prep work but well worth it in the end, everything looking good.
