Now that I need the tank parts to dry I decided to fit the leading edge on permanently. I had my two lovely children help and this speeded things up a bit. I had Alexander place the correct rivet size into the holes (His little fingers worked a treat in placing the small rivets in) I squeezed them with the hydraulic squeezer and my daughter Imogen pulled out the cleco's as we went. After this I finished deburring and dimpling the underside ribs and then ran the electrical conduit through the holes I made in the ribs.
