I had to make a 90 degree bend coming out from the pitot attachment from the wing root, with aluminium pipe and fitting, I should have done this before the wing was attached as it was quite difficult. Ended up using plastic tubing going over the aluminium pipe, clamped and silastic, with 90 degree bends, and covering these with silastic as well to reduce leaking.
