Drilled hole in the firewall, mounted the EGT's by measuring 3" from the top of the exhaust on each, drilled and safety wire through the clamp, ran and connected the EGT's and CHT's to the wiring loom from the Dynan. Also connected and ran wires to the amps shunt. Clipped the spark plug leads up, shortened the two front leads.
