Engine is coming. So I need to remove the wings so I can get my plane down from the workshop 2nd story. Heart in mouth stuff I tell you, when lifting it down. I bolted on the rudder for the final time, fitted the plastic rudder stop as well. I also removed the ailerons because with the pushrod I made a few years ago, it stated one end had rivets used and the other end could be welded. I welded one end but decided I may as well fit a rivet in as well for extra protection, so redid these and fitted ailerons back on, happy now.
