Epoxy glued the 2nd attempt fairing onto the right wheel pant, once dry I ground down the excessive epoxy with a die grinder with sanding disc, a lot better, looks alot like the left pant (as it should). The I layed up some fibreglass over the fairing to add strength. Do the final finishing mount touchups to the front wheel pant. Drill/countersink and rivet on hinge for front leg cover.
