A lot of fiddling and trying to get the canopy fairing to sit flat. I re-cut and trimmed again as I wasn't happy. Primed, sanded and painted the inside again with the interior 2 pak color. I figure I can work better on the fairing if it is actually riveted to the canopy. So using industrial silastic I joined the fairing and canopy together, also using rivets and the bolts. Sand back any high spots and using filler smeared over the rivets and bolt heads. I'm starting to think is turning out very nice, bit more sanding and filling and should be there.
