Brief Description: continuation of elevator control
Fabricated cross diagonal to mount the pulleys on. Mounted pulleys to plate and tack-welded plate in place. Ran strings to simulate cable routing. Operation looks good. 4" of stick movement = 1 1/2" of elevator horn travel = 24 degrees of travel from neutral each direction.
