CHRIS'S WEB SITE
RV-8
Started Forward HS Spar
Started forward horizontal stab spar. Ground angle brackets to correct taper. Match drilled HS-00003 spar doublers.
Note for future builders: use the dimension from B-B (1-7/8") to space the doublers.
Taper on Angle Brackets
Spar Doublers
RV-8 Home
