Modified the air filter box to match the inlet of the James cowl. I patched the existing box up with packaging tape and built up the new shape with bondo. After snading I applied another layer of packaging tape over the bondo and layed up a new fiber glas shell. After curing I removed the sheel and mated it to the filter box, and roved the parts of the filter boc that I didnt need. The new filter box will mate with the inlet which will have a thick rubber seal to go in between the inlet and the filter box.
