Brief Description: Installed wiring for right wing electrical
Moved to page 40-05 to install wiring for right wing. Installed and routed the following wires per step 10. WH-B212 Nav Power wire, WH-B213 Pulse power wire, WH-B203 strobe power wire, WH-B318 strobe sync wire, WH-B214 landing light power wire. Installed 2 additional pull strings. Attached wires shown above and in Figure 3 to ES-00077 floating 8 position female connector for right wing per step 8. Also installed the WH-B216 ground connection. Installed ES-00077 connector per step 11. Completed steps 1-3 page 40-04 for landing light ribs W-1223B-L and W-1223B-R. Completed steps 4 and 5 for W-1223C rib doublers. Primed parts.
