Johns Web Site
Date:  6-15-2013
Number of Hours:  5.00
Brief Description:  Working on Build Fixtures
Prior to resuming the build activity I decided to build a number of fixtures that I had seen in the VAF forum that others had used successfully during their build activity. Figured this was a good time to get them out of the way so that I could proceed then without need to stop later on. Built a set of support frames to allow the construction of the rear portion of the fuselage and also a set of heavy saw horses of the proper height that will be used to handle the completed plane.
