Johns Web Site
RV-12iS
9.0 Horizontal Stabi
12-31-2012
Prep of HS skins
Step 1 page 09-08. Worked on HS-1201R and HS-1201L skins. Removed protective coverings on inside surfaces and around the rivet holes on outside. Completed prep of HS-1201R skin edges and holes.
HS Skin Preps
HS Skin Preps
HS Skin Preps
RV-12iS Home
1448
10.0 Tailcone
11.0 Empenage Assemb
11.0 Empennage Attac
11iS Empenange Attac
12iS Emmpenage Fairi
13.0 Wing Spar Assem
14.0 Rear Spar, Stub
14.0 Wing
15.0 Wing Ribs
16.0 Stall Warning
17.0 Wing Skins
18.0 Flaperons
20.0 Fuselage Center
20is Center Section
21.0 Mid Fuse Ribs a
21IS Mid Fuse Ribs a
22.0 Fwd Lower Fusel
22iS/U FWD Lower Fus
23.0 Fuselage Side S
23iS/U Side Skins
24.0 Rollover Struct
24iS/U Rollover Stru
25iS/U Seatbacks
26.0 Seat Backs
26iS/U Fuel Tank
27 iS Fuel Syste
27.0 Rudder Pedals a
27iS/U iS Fuel Syste
28.0 Fuel System
28iS/U Rudder Pedals
29A.0 Fwd Upper Fuse
29iS/U FWD Upper Fus
32iS/U Flight Contro
35GiS/U Preminum Bra
35iS/U Landing Geat
40.0 Lighting
6.0 Vertical Stabili
7.0 Rudder
7A Trim Tab
8.0 Anti Servo Tabs
Empennage/Tailcone K
Fixtures
Hangar
SB 18-02-03 AST
SB180202
